AutoCAD Civil 3D General
ozaukeelandwater
Message 1 of 7 (1,135 Views)
Export lines as shapefiles to ArcMap
1135 Views, 6 Replies
12-15-2009 08:24 AM
I am trying to map export shapefiles to arcmap, but it keeps telling me export did not succeed. Any suggestions?? Thank you.
*John Mayo
Message 2 of 7 (1,135 Views)
Re: Export lines as shapefiles to ArcMap
12-15-2009 08:37 AM in reply to: ozaukeelandwater
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13251791&linkID=9240697
This may help. There is another I don't have time right now..
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
*Murph
Message 3 of 7 (1,135 Views)
12-15-2009 02:03 PM in reply to: ozaukeelandwater
Are they basic AutoCAD lines or Civil 3D objects?
Murph
http://map3d.wordpress.com/
"Ozaukeelandwater" wrote in message news:6305119@discussion.autodesk.com...
ozaukeelandwater
Message 4 of 7 (1,135 Views)
12-15-2009 02:19 PM in reply to: ozaukeelandwater
The lines are polyline (2D polyline).
*Murph
Message 5 of 7 (1,135 Views)
12-16-2009 04:57 AM in reply to: ozaukeelandwater
File location and name, set the file location close to the C:\\ not buried
in a wad of subfolders, give the file a simple name like ABC.shp
Then of course you read John Mayo's reply right, and you are selection line
as the type of export and selecting objects not on a locked layer. What
attribute information are you exporting with the lines? Is the dwg a newer
dwg or a old dwg that's been around for years? Are the polylines lwplines?
Might try running the convert command if they are the old style polylines.
Murph
"Ozaukeelandwater" wrote in message news:6305376@discussion.autodesk.com...
New Member
mkapono
Message 6 of 7 (1,081 Views)
12-16-2010 05:52 PM in reply to: *Murph
Hi there:
John Mayo's referenced post (http://usa.autodesk.com/adsk/servlet/ps/dl/item?si​teID=123112&id=13251791&linkID=9240697) could not be located in the Discussion archive. I have a post on the Autodesk EduComm board regarding interoperability of Student version Civil 3D and ESRI ArcMap via widget from ESRI. Is aforementioned reference still available?
Thanks from a newb to the boards. -- Mark
________________________________________________
T400-2764CTO
Intel T9400x2@2.53GHz 4GB
Radeon HD 3400
MSVista x86
Valued Contributor
eladkcem
Message 7 of 7 (321 Views)
11-30-2012 10:19 PM in reply to: *Murph
Not sure why, but I got the same error message late this evening...
moving my target directory close to c:/  solved the problem...
Thanks murph.
-d
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
