AutoCAD Civil 3D General Discussion
elijahvoigt
Message 1 of 4 (504 Views)
Accepted Solution
Export Station Offset Of Points To An External File?
504 Views, 3 Replies
02-07-2014 08:06 AM
Hello. I wanted to see if anyone knew of a way to export station-offset data of points relative to a specified alignment? Possibly to a csv. Thanks
Civil 3D 2014
i7-3930K Overclocked
32 GB Ram
Windows 7 Professional
*Expert Elite*
wfberry
Message 2 of 4 (501 Views)
Re: Export Station Offset Of Points To An External File?
02-07-2014 08:23 AM in reply to: elijahvoigt
I can get you started.
Bring up the "Create Points" dialog panel.
In the 3rd drop down menu, you have two alignment options, DIVIDE & MEASURE Alignment.
Use the Measure and select (frequency you want, 25 or 50, etc.)  Remember to give it an even starting station or you will have a MESS!
Before you start trying out this process, save your file.  If you mess up it is a lot easier to  "not save" and re-start Civil 3D.
Also, under Create Points -> Points Creation you need to change PROMP FOR DESCRIPTIONS to Automatic-Object.
The last statement (above) I may be off on that but I have you in the right Church, maybe in the wrong pew.
Make sure you locate these points in an appropriate Point Group, then you can export them quite easily.
Bill
Windows 7 x 64 Professional
Nvidia GeForce 9800 & 8500
12 GB Ram
i7 965 @ 3.20 GHz
Corsair Force 240 GB SSD
Infrastructure Suite 2014 Premium SP1
*Expert Elite*
Jeff_M
Message 3 of 4 (493 Views)
02-07-2014 09:05 AM in reply to: elijahvoigt
There is the "Station Offset to points" report in the Toolbox that should get you what you want.
Jeff_M, also a frequent Swamper
elijahvoigt
Message 4 of 4 (485 Views)
02-07-2014 09:27 AM in reply to: Jeff_M
Just what I needed Jeff. Thank You!
Civil 3D 2014
32 GB Ram
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
