Civil 3D Forum
Export Section information to .CSV
2 REPLIES 2
768 Views, 2 Replies
Good Morning,
My Engineer has a Hec-ras file that he has been working on and I need to change some of the sections. I don't want to re-export all of my sections to a .goe file and lose the work he has already carried out.
Is there any way of exporting the necessary sample line information into a CSV file, as I believe this will be the best way to make the changes to the hec-ras data without losing the work which has already been carried out.
Any help with this would be greatly appreciated.
Kind Regards
Louise
2 REPLIES 2
KirkNoonan
You can select the section line itself, list it, and copy the station / elevation values from the command window and paste them into your spreadsheet.
you can use "task pane" then use query, and filter the lines you want to know. You can make a report doing that save with the extention .csv and youre done
if you need help making it so let me know
Rail Community
