AutoCAD Civil 3D General
Member
Message 1 of 3 (151 Views)
Export Section information to .CSV
151 Views, 2 Replies
11-27-2012 03:25 AM
Good Morning,
My Engineer has a Hec-ras file that he has been working on and I need to change some of the sections. I don't want to re-export all of my sections to a .goe file and lose the work he has already carried out.
Is there any way of exporting the necessary sample line information into a CSV file, as I believe this will be the best way to make the changes to the hec-ras data without losing the work which has already been carried out.
Any help with this would be greatly appreciated.
Kind Regards
Louise
Valued Mentor
Message 2 of 3 (144 Views)
Re: Export Section information to .CSV
11-27-2012 05:39 AM in reply to: L0uise
You can select the section line itself, list it, and copy the station / elevation values from the command window and paste them into your spreadsheet.
New Member
Message 3 of 3 (136 Views)
11-27-2012 06:14 AM in reply to: L0uise
you can use "task pane" then use query, and filter the lines you want to know. You can make a report doing that save with the extention .csv and youre done
if you need help making it so let me know
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
