Civil 3D Forum
Export Parcel Analysis: curve delta is showing decimal degrees
4 REPLIES 4
IanMcClain
718 Views, 4 Replies
How do I get the export parcel ananlysis to show degrees minutes and seconds instead of the default decimal degreees. My direction settings are set to DMS, but I can't see where to change arc deltas...
Ian McClain
4 REPLIES 4
IanMcClain
in reply to: IanMcClain
Found it: Angle settings. Duh.
Ian McClain
1wildwes
I've set the Parcel analysis format to Degree/DD.MM.SS, set ambient settings to Change Commands, saved both but still the report shows curves in decimal format.
IanMcClain
in reply to: 1wildwes
That sounds correct. Have you checked for an override in Toolspace>Settings>Parcel>rightclick-"Edit Feature Settings"> Angle?
Ian McClain
1wildwes
It's in the Edit Drawing Setting>Ambient Settings>Angle. All good now.
Rail Community
