AutoCAD Civil 3D General
*Expert Elite*
neilyj
Message 1 of 6 (195 Views)
Export Corridor to earlier Civil 3D version
195 Views, 5 Replies
01-15-2013 03:43 AM
Can this be done? The XML export seems to have all the information to be able to recreate it but the XML import doesn't seem to import the information
See also http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Exporting-corridor-to-LandXML/td-p/3672598#.UPVAi2ein...
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Product Support
AlmasSuljevic
Message 2 of 6 (158 Views)
Re: Export Corridor to earlier Civil 3D version
01-16-2013 08:13 AM in reply to: neilyj
The corridors are not being included in the LandXML import scheme, I suppose since they depend on many things such as assemblies which are not supported by LandXML. If you look at the LandXML Settings in Settings tab you will see that it does not have import settings for corridors. If you also go to LANDXMLIN command you will see that corridor is not part of import.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
*Expert Elite*
neilyj
Message 3 of 6 (152 Views)
01-16-2013 08:31 AM in reply to: AlmasSuljevic
I realise that the assemblies are not supported but when you look inside the XML file all the data required to rebuild a static corridor seems to be available.
The answer to the original question would therefore appear to be it can't be done?
Is this more evidence of the fallability of the policy of incompatible annual releases i.e. corridors can't be shared with earlier versions ?
neilyj
*Expert Elite*
sboon
Message 4 of 6 (124 Views)
01-16-2013 10:12 PM in reply to: neilyj
As far as I know it has never been possible to import a corridor via xml, even from another drawing of the same version.  The data exported can be used by other software, particularly survey layout programs to create a static version of the corridor but without surfaces, assemblies and other components Civil3d would not be able to recreate a true corridor in another drawing.
*Expert Elite*
neilyj
Message 5 of 6 (106 Views)
01-17-2013 04:50 AM in reply to: sboon
So the upshot is the corridors cannot be shared with earlier versions of the program??
Civil 3d again proving itself to be incompatible with itself which is a bizarre situation...!!!!
neilyj
*Expert Elite*
Message 6 of 6 (99 Views)
01-17-2013 06:34 AM in reply to: neilyj
This is a theory since I don't know much about the LandXML language. Since it is a global language, it's possible that corridors are not compatible with XML. Autodesk does not control XML that I know of so maybe it's just not possible from their perspective.
Just a thought.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
