New Member
MattBithell
Message 1 of 2 (125 Views)
Export 2D Level Banding?
125 Views, 1 Replies
01-16-2013 01:46 AM
We use 3DC for basic cut/fill models and tend to use the same banding depths so in metre intervals from -10 say to +10. To remain consistent we like to keep the banding the same. I wondered if there was any way of exporting a banding set or colour scheme from project to project or surface to surface.....
autoMick
Message 2 of 2 (120 Views)
Re: Export 2D Level Banding?
01-16-2013 02:41 AM in reply to: MattBithell
Yes there is... go to the toolbox tab on your toolspace window. If you run UKIE or ANZ templates you should find under "additional tools" that you have "surface analysis - export to a file", and similarly to import to a file. I use this all the time and I recommend reading the thread that put me onto it: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Custom-color-range-for-surface-elevations/td-p/339635... In it you will find some useful tips from Andrew Puller on how to add a bit of flexibility.
Regards
- Mick
Infrastructure Design Suite Premium 2014
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), Win7Pro64, Quadro K4000
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
