Hi, everyone.
I have a little problem. When I export my Civil file (which in relief Surface model) to DWG-file format for the AutoCAD users the TIN model changes to "3D Face" objects. But when I gonna to explode these 3D Face objects whith the command "explode" they I can't do it. How can I to explode it? Who did proccess like it?
Solved by neilyj666. Go to Solution.
you can start command _REGION to convert a 3d-face-object into a region object, then you can explode this region object to get the 3d-lines.
Just out of curiosity ... what do you need that for?
- alfred -
Thanks, Alfred for idea.
But I didn't undrestud your question - the last sentence.
neilyj (No connection with Autodesk other than using the products in the real world)
Because, I gonna to change elevations of Surface points (not COGO poins) and creat Surface again using TIN lines like breaklines.
If you are using a style that shows your tins, you extract the linework using the extract objects tool in surface tools.
I see - you'll also need to extract the points from your original TIN and convert to cogo in order to edit them easily.
Your exploded Tin Lines (Region > Explode) may need to be Flattened to 0 and used as proximity breaklines or the TIN may use the z values from the exploded TIN lines (not sure exactly on this one though)
I have extracted TIN and points from Surface. And using that lisp I can explode TIN. I will exchange points to COGO points, will edit points and after it with these points I will creat Surface again (using TIN-lines like proxmity breaklines). That is what I want to do.....
Thanks everyone!
