Civil 3D Forum
Explode TIN
10 REPLIES 10
Message 1 of 11
3120 Views, 10 Replies
Explode TIN
Hi, everyone.
I have a little problem. When I export my Civil file (which in relief Surface model) to DWG-file format for the AutoCAD users the TIN model changes to "3D Face" objects. But when I gonna to explode these 3D Face objects whith the command "explode" they I can't do it. How can I to explode it? Who did proccess like it?
10 REPLIES 10
Message 2 of 11
Alfred.NESWADBA
you can start command _REGION to convert a 3d-face-object into a region object, then you can explode this region object to get the 3d-lines.
Just out of curiosity ... what do you need that for?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 11
in reply to: Alfred.NESWADBA
Thanks, Alfred for idea.
But I didn't undrestud your question - the last sentence.
Message 4 of 11
neilyj666
He's just asking why you need to explode the 3D faces?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 11
in reply to: neilyj666
Because, I gonna to change elevations of Surface points (not COGO poins) and creat Surface again using TIN lines like breaklines.
Message 6 of 11
If you are using a style that shows your tins, you extract the linework using the extract objects tool in surface tools.
Message 7 of 11
neilyj666
I see - you'll also need to extract the points from your original TIN and convert to cogo in order to edit them easily.
Your exploded Tin Lines (Region > Explode) may need to be Flattened to 0 and used as proximity breaklines or the TIN may use the z values from the exploded TIN lines (not sure exactly on this one though)
Message 8 of 11
neilyj666
See also here http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Convert-3D-face-to-linework/td-p/3602448
Message 9 of 11
neilyj666
That will only get the triangles though (and 3d faces when exploded which is what the problem is)
Message 10 of 11
Thank you very much, neilyj.
I fined 3DFTO3DP.LSP form the link which you show here. And it heled me...
Message 11 of 11
I have extracted TIN and points from Surface. And using that lisp I can explode TIN. I will exchange points to COGO points, will edit points and after it with these points I will creat Surface again (using TIN-lines like proxmity breaklines). That is what I want to do.....
Thanks everyone!
Rail Community
