Just wondering if there was a way to compare a Profile Centerline Elevation to a Picked offset Point on a Surface.
What i need is to be able to read the centerline profile elevation at a station then read the surface elevation at the same cl station but at an offset then subtract the two and display the resultant.
C3D 2010 SP2
I think the only way is to create an profile from surface that is offset the distance you want and then use a profile or profile view label to compare the elevations. If your offsets aren't the same throughout, not a solution I'd look forward to.
Christopher
