Civil 3D Forum
Existing elevation flag
8 REPLIES 8
Message 1 of 9
dbanaszak
536 Views, 8 Replies
When working in a drawing with a surface referenced there is usually a flag attached to the cursor that reveals the surface and the elevation of the spot the cursor is hovering over; mine has disappeared. How do I get it back? Thanx
8 REPLIES 8
Message 2 of 9
ccl_cad_manager
in reply to: dbanaszak
Open up the surface properties, on the information tab, lower left.  Is Show Tooltips checked?
MikeC
Civil 3D 2015, Win 7 64bit, 16 GB RAM, Dell M4600
''That's the way we've always done it'' is an excuse, not a reason.
Message 3 of 9
dbanaszak
I'm very new to this interface (used to be an ace at LDD) so you're going to have to walk me right into this one. If you give me click by click from the HOME tab I'd really appreciate it since I've only seen the TOOL TIPS box in the PREFERENCES dialog. Thanx
Message 4 of 9
ccl_cad_manager
Sure,
Click on your surface in the drawing area so that it's the only active object.
Right Click, Move your cursor down to Surface Properites
You'll get a dialog box with 4 tabs (Information, Definition, Anaylsis, Statistics) Click on Information
Lower Left Hand Corner there's two check boxes, one for tool tips, one for locking.
Turn the Show Tooltips on.
(edited to add location)
MikeC
Message 5 of 9
dbanaszak
Mike,
I usually get there THROUGH TOOLSPACE and then SURFACES then right clicking on the surface name then SURFACE PROPERTIES, so I know now where I needed to be. The Show tooltips button is checked.
I know I was seeing the tool tip in a drawing into which I had XREF'd the surface, but I'm not sure why the tool tip would disappear. Thanx
Message 6 of 9
Jay_B
Are the following variables all set as follows?
ROLLOVERTIPS=1
TOOLTIPS=1
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 9
troma
Also note the layer the surface is on needs to be thawed and turned on. If it is off the surface will usually still display, but the tooltips won't.
This could be layer C-TOPO or 0, or whatever you have it set to.
Mark Green
Working on Civil 3D in Canada
Message 8 of 9
dbanaszak
Jay,
ROLLOVERTIPS it was. In the master drawing that we XREF it was showing station information, while in my drawing that contains the master as an XREF it shows the surface and the elevations associated with it. What controls this? Thanx
Message 9 of 9
Jay_B
If you Dref your Alignment into the drawing not showing the stationing info, you will see it there in Rollovertip as well.
It must be able to read the alignment.
C3D 2018.1
C3D 2016 SP4
Rail Community
