When trying to make an existing features cooridor when I select Target to set the existing surface I get an error
"No target foun in the scripts."
I have attached a word file with the error as it appears on the screen
Edited by
Discussion_Admin
Solved by Jeff_M. Go to Solution.
I'm using the FDOT existing features subassembly from the FDOT State kit. The subassembly is coded to tie to existing features i.e. road, sidewalk.
