Civil 3D Forum
Excel Table Named Range?
5 REPLIES 5
DaveM
1468 Views, 5 Replies
All,
I am sure I am missing some small detail. I am trying to insert an excel table using a datalink. If I insert the entire sheet, it includes too many cells. If I set a print area and choose that area, it will not insert the table. The first time it acts like it is going to work, but then never lets me place the table. The second attempt it just will not let me select that data link. If I actually name a group of cells, I get the same behavior as the print area. Does anyone else have issues with importing excel tables? Am I missing a step?
My work flow is
Create an excel sheet & format the table.
Select desired sells, set print area.
Save & Close excel
go to annotate tab in civil 3d
select table icon
choose from data link
launch data link manager
create data link and choose range of cells as print area.
Press OK
it never let me choose insert point.
I have also tried to simply make the datalink and then run the table command with the same results.
Any suggestions?
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
5 REPLIES 5
doni49
in reply to: DaveM
That's odd.  I can't even get it to let me place it if I do the entire sheet.
I'm using C3D 2012.
It shows up fine in the preview (including being just the correct cells) regardless of choosing Entire Sheet, Link to Named Range or just Link to Range.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
DaveM
in reply to: doni49
Don,
I do not typically get a preview. I am using 2013, but i have never tried inserting a table before 2013.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Jay_B
in reply to: DaveM
Here's how we link Excel using datalink here.
1. In Excel select the cells of data to be linked to AutoCad. Right click and select “Copy”.
2. In AutoCAD / C3d navigate to Home Tab on Ribbon>Paste>Paste Special.
3. Select Paste Link>AutoCAD Entities>OK.
Then set up the various cell table styles as desired for Data, Header, Title.
To Modify Datalink settings go to Select Insert Tab on Ribbon>Linking & Extraction>Data Link.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
DaveM
in reply to: Jay_B
Jay,
That worked out great and was much quciker than anything I have done in the past. The only issue I noticed was the cells that were formated to have verticle text came in funky.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
DaveM
in reply to: DaveM
Jay,
Will you be at cad americas in cincinatti on November 12 by any chance?
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Rail Community
