Civil 3D Forum
Every Survey Database isLlocking
4 REPLIES 4
scohen
761 Views, 4 Replies
All,
I have searched the discussion groups to see if anyone else has had this problem, but I haven't found anything.  Here is whats happening, every time I create a new survey database, I can edit it fine, Import survey data, etc..  As soon as I set another survey database active, it states "This item cannot be edited".  When I activate the one I just created, it then also states the same.  So, every time I create a new survey database, it ends up locking and I cannot edit it at all.  Yes, I have checked all permission spots, and yes, I have restarted my machine.  Any advice is greatly appreciated
Thank you in advance.
-Seth Cohen
Lenovo Thinkpad
Windows 7 64-bit
Civil 3D 2012
8GB RAM
1GB nVidia
Tags (1)
4 REPLIES 4
AlmasSuljevic
in reply to: scohen
Hello Seth,
Can you change Working Folder and see if you get the same error? it seems like install may gone bad.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
scohen
in reply to: AlmasSuljevic
Hi Almas,
First, thanks for responding.  I actually figured it out; I meant to post what it was here.  I was double-clicking the survey databases, not realizing that that opened it up read-only by default.  I now realize you have to right-click Open for Edit (Duh :-).
Thanks again.
-Seth Cohen
AlmasSuljevic
in reply to: scohen
Great!. Thanks for sharing.
Almas Suljevic
Autodesk, Inc.
in reply to: scohen
Thanks for your suggestion.
Rail Community
