AutoCAD Civil 3D General
Active Contributor
dbussie
Message 1 of 3 (121 Views)
Event Viewer Error Message When Rebuilding Corridor
121 Views, 2 Replies
11-06-2013 01:08 PM
Hi everyone.
I'm getting several messages saying "value on wrong side of alignment" when I rebuild my corridor.  I've checked the two target alignments that I'm using and they are on the correct side.  Any ideas on what is causing this error?
Thanks!
Desirea
FBL & Associates
Civil 3D 2014
*Expert Elite*
mathewk
Message 2 of 3 (111 Views)
Re: Event Viewer Error Message When Rebuilding Corridor
11-06-2013 05:01 PM in reply to: dbussie
That error usually means you have a lane or something on the left of the assembly and a width target on the right. Attach rhe dwg.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Active Contributor
dbussie
Message 3 of 3 (92 Views)
11-07-2013 06:09 AM in reply to: mathewk
It says my file is too large to attach.  Is there any way around this?
 I get that error for two stations on my FG model and several stations on my SG model.  There are only 2 alignments that I'm targeting (Target 1 and Target 2)
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
