Civil 3D Forum
Error performing edit, Pasting a voulume surface into a TIN surface
3 REPLIES 3
sweeneypaul0
1159 Views, 3 Replies
Hi All
I am receiving the following error message when trying to paste a volume surface created form peat probe depts and existing ground profile  into a newly created blank TIN surface
"Error performing edit"
just for more information i am following the precedure documented here and am experiencing the problem in step 3 of the solution to the
Creating Geological Surfaces from Probed Depth Values section.
I am running Civil 2014. Any ideas on what i am doing wrong
Regards
3 REPLIES 3
neilyj666
in reply to: sweeneypaul0
I use this technique regularly with no issues but without seeing the drawings it'll be difficult to say what is happening (or not).
Can you post the files?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
I usually get the error when a surface becomes corrupt. If you do an audit you may see Civil 3D do some horrible operation to "fix" the surface or as I like to say "demolition it" with badness. The error in my experience comes from a corridor boundary that Civil 3D decides it doesn't like any more. Try removing it from the surface and try again. I've also suspected when a surface is pasted with the same named boundary causing these types of issues.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
sweeneypaul0
Cheers for your responses guys i managed to repeat the process for another situation and it worked fine. Unfortunelty I have lost the original file i was working on so i cant quite confirm what was said was the solution. i did take on board teh points about the naming structure and the use of boundaries so perhaps these are significant points. Apologies for the delay.
Cheers
"Wherever you go, there you are"
Rail Community
