I've gotta figure this error out, because I am completely stuck for the moment. The following error is issued when I create sheets using the createsheets command:
Type: Error
Date: 5/28/2010
Time: 11:18:54 AM
Source: Create Sheets
User: Acer
Description: Unable to create multiple profile views
When the sheet files are created, I receive an error is issued during save that prompts me to run recover on the files. Recover produces the following output:
######## begin recovery log ########
Drawing recovery.
Drawing recovery log.
Error 0 reading handle table. Reconstructing from objects.
Reconstructing handle table from objects.
Scanning for objects 100% done
6134 objects found.
Scanning for objects completed.
Salvaged database from drawing.
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 5700 objects audited
Non XREF-dependent record "CONST|PHANTOM" contains vertical bar.
Changed to "AUDIT_I_100528113057-0".
Pass 1 6100 objects audited
Auditing Entities Pass 2
Pass 2 100 objects auditedAcDbLine(825) Null Owner
Placed in $AUDIT_BAD_BLOCK_RECORD1
AcDbLine(826) Null Owner Placed in
AcDbLine(827) Null Owner Placed in
AcDbLine(828) Null Owner Placed in
AcDbLine(829) Null Owner Placed in
AcDbLine(82A) Null Owner Placed in
AcDbLine(82B) Null Owner Placed in
AcDbLine(82C) Null Owner Placed in
AcDbLine(82D) Null Owner Placed in
AcDbLine(82E) Null Owner Placed in
AcDbLine(82F) Null Owner Placed in
AcDbLine(830) Null Owner Placed in
AcDbLine(831) Null Owner Placed in
AcDbLine(833) Null Owner Placed in
AcDbLine(834) Null Owner Placed in
AcDbLine(835) Null Owner Placed in
AcDbLine(836) Null Owner Placed in
AcDbLine(837) Null Owner Placed in
AcDbLine(838) Null Owner Placed in
AcDbLine(839) Null Owner Placed in
AcDbLine(83A) Null Owner Placed in
AcDbLine(83B) Null Owner Placed in
AcDbLine(83D) Null Owner Placed in
AcDbLine(83E) Null Owner Placed in
AcDbLine(840) Null Owner Placed in
AcDbLine(841) Null Owner Placed in
AcDbLine(842) Null Owner Placed in
Pass 2 6100 objects audited
Auditing Blocks
74 Blocks audited
Total errors found 28 fixed 28
Erased 0 objects
####### end recovery log ########
I am creating plan and profile sheets from a group of two view frames along an alignment. I had created profiles from this alignment before without receiving this error. I am not sure what changed, but now I receive this error. It does not matter if I choose to include the sheets in the current drawing, or another dwg file. I also does not matter if I choose a pre-configured profile view or define one with the wizard. I tested the createsheets process after receiving this error by following the online tutorials available at the AutoDesk website, and the process worked fine. I have attempted to create sheets with another version of the file that I am using, and received the same error, so I don't think that there is a setting in the file itself that is problematic. I also tested with the standard Imperial Plan and Profile template issued with the software, and the error occurred with this template, too. Please let me know if you need more information. Thank you.
