I am working in AutoCAD Civil 3D as AutoCAD 2013. I have a drawing that has three images loaded in the drawing. 1 is a .jpg and 2 are .bmp's. When i click the save icon, type save, type saveas, type qs i get the attached pop up. It says it wants to delete one of the .bmp images. Please help.
Solved by james.hines613. Go to Solution.
Mark Green
Working on Civil 3D in Canada
if I click yes on the pop window, my image does disappear. If i click no, the image stays and dwg is saved. i just tried the .QSAVE and pressed F2. Attached is a screen shot of that dialog box.
Also, I am not seeing this issue with any of my other drawings. Not sure if it is something in that particular dwg or what.
I have seen the message myself, but only when all instances of an image actually have been erased from the drawing. The program recognizes that the attachment reference is likely no longer needed, and offers to detach it. It seems in your case there is something wrong.
Have you tried:
Recover the drawing?
Audit the drawing?
Mark Green
I have tried the audit....0 errors.....I just did a recover on the file. Once it finished and the drawing opened, the same Erasing Image box popped up. The recovery showed no errors also. Should I Etransmit and upload the zip file for review?
I figured it out....someone had inserted the image as a block....sorry to waste time.
Mark Green
