Hello
I just started receiving this error the equipment DB does not exists or could ne be reached.
The MS Jet DB engine stopped the process because you and another user are attempting to change the same data at the same time.
These users are using a standalone version of civil 3d 2010.
Solved by SethHall. Go to Solution.
Hi morty141-
I seem to recall this error message occurring when the SAMPLE.EDB & SAMPLE.FDB files, located here:
C:\Documents and Settings\All Users\Application Data\Autodesk\C3D 2010\enu\Survey
or here:
C:\ProgramData\Autodesk\C3D 2010\enu\Survey
have become corrupted on a machine. To resolve this please copy these files from a working machine and see if that helps.
