Distinguished Contributor
Happyunited123
Message 1 of 5 (1,143 Views)
Embankment/Daylight Query
1143 Views, 4 Replies
10-01-2013 01:44 AM
I'm building up my assembly and I want to add a daylight sub-assembly in order to grade my proposed surface to the existing surface. Typically I would have a 1:3 slope up or down. I have choosen the DaylightGeneral for this and although there is quite a few parameters to play with, I'm only interested in the up/down slope but when I put anything sleeper than 1:4 it doesnt work, I get this red line and circle. Can anyone tell me why?
Thanks in advance.
*Pro
dgordon
Message 2 of 5 (1,132 Views)
Re: Embankment/Daylight Query
10-01-2013 04:23 AM in reply to: Happyunited123
Daylight general has 3 cut situations and 3 fill situations. the flat fill slope can't be steeper than the steep fill slope. If you do this i think it will give you the situation your talking about. so if you want 1:4 steep slope put in 1:5 med slope and 1:6 flat slope.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
sboon
Message 3 of 5 (1,112 Views)
10-01-2013 08:57 AM in reply to: dgordon
Dan has it right.  DaylightGeneral also has height limits for the test of flat slopes vs. medium or steep slopes.  You need to make sure that the flat limit < medium limit < the steep limits.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Valued Mentor
david.zavislan
Message 4 of 5 (1,085 Views)
10-02-2013 08:45 AM in reply to: Happyunited123
I find that the DaylightGeneral subassembly is not very general.  For simple models, with single cut and fill slopes, I use the DaylightMaxWidth.  It has fewer properties, which makes it easier to use.  Just make sure to specify a maximum width value that will not constrain the slope.
David Zavislan, P.E. | Wood Rodgers, Inc.
Happyunited123
Message 5 of 5 (1,048 Views)
10-08-2013 07:33 AM in reply to: david.zavislan
Thank you all for the answer, worked a treat.
I do however agree that the daylightgeneral is a bit complicated for something 'general'.
