I have imported a survey file. When I insert the points into the drawing, the elevation changes to something that isn't even recognizable. When I view the point in the survey tab, the elevation is correct, when I view the point in the prospector tab it is different. What is going on?
@dgc74 wrote:When I insert the points into the drawing, the elevation changes to something that isn't even recognizable. When I view the point in the survey tab, the elevation is correct, when I view the point in the prospector tab it is different.
What is meant by unrecognizable? Is the difference consistent if you divide the 2 values for a few random points?
Can you give an example of what the value for point #100 is in Survey tab vs. point #100 in Prospector tab?
Posting some captions of same points for correct and incorrect may help.
Without more information, 2 possibilities that come to mind are:
1. Units in Drawing differ from those in Survey Settings.
2. Point group could have an override for the elevation value.
Yes both settings match. I took a closer look and my Northings and Easting had shifted as well. If I use the Import points file vs import survey data....the N,E,ELEV do not shift.
I also check the setting for the "survey" under the settings tab and it is metric as well.
