Civil 3D Forum
Elevation Editor won't open
2 REPLIES 2
dorkyfreak
6484 Views, 2 Replies
Has anyone have trouble opening the elevation editor for the feature line? Everytime I click it via Ribbon, nothing happens, as if there's no such thing as the elevation editor. Is there some settings I need to do? is it a common glitch in the 2012? So far, the only way I can edit the elevation is via the command line, but that way can be confusing.
2 REPLIES 2
bruce.jordan
in reply to: dorkyfreak
The Elevation Editor is contained in the Panorama (same as your Event Viewer).
Is your Panorama displayed somewhere on your screen?
If so, is the Grading Elevation Editor tab set current (you might have several tabs in Panorama)?
You mention - "Everytime I click it via Ribbon", how about the pulldown menus (menubar = 1)?
Do you still have the problem using the Grading pulldown menu?
-Bruce
dorkyfreak
in reply to: bruce.jordan
Wow! it is in the panorama viewer. I had the viewer autohide and on my second monitor, so it was not obvious when the editor appeared. Thank you so much for pointing that out!
Rail Community
