Civil 3D Forum
Elevation Banding Color Change
6 REPLIES 6
rhalley
4228 Views, 6 Replies
Is there a way to change or create a new scheme (banding) by elevation? For eg. I would like to use only a range of grey no other colors.
6 REPLIES 6
h1dekikun
in reply to: rhalley
Right click on the TIN Surface - select surface properties. Go to the Analysis Tab, and for the Analysis Type, click on Elevations. For Ranges, select how many bands you want and click the little down arrow. You can change  the colours of each band and sizing of each band under the range details.
emmar0001
But if I wanted this colour scheeme to be a 'fixed' feature for all of my projects, how could I save this colour scheme as a template?
C3D 2010
Intel Core 2, Windows XP
2.67GHz, 3GB RAM
cambium
in reply to: emmar0001
I don't believe you can.  I've spent some time trying to do the same thing and come up with nothing.  It's definitely a short-coming.
mathewkol
There was a LISP floating around which enabled you to export colours and then import. Find it and you'll have a solution.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
mathewkol
Found it.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Export-Import-Surface-Analysis/td-p/314...
Matt Kolberg
ksorsby
in reply to: mathewkol
Doesn't work though on grid surfaces created from a DEM ie. a grid of LiDAR points.
Kevin
Rail Community
