Unfortunately, it takes a couple small steps to get it all rotated, if you
don't have a direction defined.
Essentially, you need to change the location of you control points, which in
turn, will update the rest of the survey. If you are rotating, you can use
AutoCAD commands to figure out what the new location of a control point
should be (turning an angle from CP 1 to move CP 2). Once you have the new
coordinates for the second control point, use the editors from the Survey
Toolspace to change the control point, and the survey will update
accordingly.
Anthony Governanti
Autodesk, Inc.
Visit my blog: www.autodesk.com/wickedcoolstuff
I dig it! Do you? Join the Civil 3D Community Now!
http://civilcommunity.autodesk.com/
wrote in message news:5373757@discussion.autodesk.com...
Also, I have read Anthony's blog on this, but what about when youhave
several Control Points? I just need an easy way to rotate the entire survey
job. Can it really be this hard?
