By selecting an indivial alignment station using control + left click, 37+00 for example, we can set the visibility from true to false so 37+00 is off but the rest of the station labels remain. Now we have a case where we need to turn 37+00 back on but cannot select it since the visibility is set to off. Is there any way to select this individual station and turn visibility back on without resetting the entire alignment label group?
Edit the Alignment labels, Major Station, to start after the station that had been set not visible, hit apply, change the start station back to what is was before, hit apply. This will bring back all of the Major Station labels from the start only. Or, if the invisible one is near the end, do the same thing from the end of the alignment.
I haven't found any. I tried with a simple lisp, naming a selection set containing a label and trying to pick it again by using that selection set name after turning the visibility off. It selected the next label down station. Not what I would have expected. My lisp skills are ancient so failure is always an option.
Allen
Allen Jessup
CAD Manager - Designer
