I'm having difficulty with a very basic operation. I have an alignment I threw together real quick. I need to change one of the PI to a curve. How can I do this? I'm looking for something similar to the Free Vertical Parabola (PVI based) under the More Free Vertical Curves on the Profile Layout Tools, but for converting a PI on a horizontal alignment to a curve.
Solved by tcorey. Go to Solution.
Pick the alignment on the screen.
On the Ribbon, select Geometry Editor.
Find the button for curves and press the down arrow. Find Free Curve Fillet (Between to Entities, Radius)
Thank you! I completely forgot there is a prompt when you run the command and was wondering why it wasn't working.
