Civil 3D Forum
Editing a Table
2 REPLIES 2
203 Views, 2 Replies
Editing a Table
I have created a table from DXE information. The table contains over1500 cells. Now i am trying to adjust the table to fit within a bordered 24"x36" sheet. I seems to take forever to make the adjustments while the table keeps recalculating. Is there a way to make the table adjustments without the table constantly updating the information contained within it?
2 REPLIES 2
Jeff_M
There's a way, but it removes any visual clue as to how it is changing.
Make sure the ActiveX API is available to lisp:
(vl-load-com)
Select the table and convert to an ActiveX object:
(setq tbl (vlax-ename->vla-object (car (entsel "\nSelect table: "))))
Suppress the updates:
(vla-put-RegenerateTableSuppressed tbl :vlax-true)
Go about the process of editing how you think it is needed.
Reenable the updates:
(vla-put-RegenerateTableSuppressed tbl :vlax-false)
You can suppress and un-supress as much as you like. It may help a bit.
Thank for the reply, I'll try it out.
Rail Community
