Is there any way to hold the focus on the selected points in the Grading Elevation Editor?
When I select some points and use raise once, the points beein deselected. And then I have to select the points again if I want to rise more.
-Or is there any easier solution to select a point or some point on a feature line and raise/lower then fast and easy by step?
Rune
thanks, but it's still a slow way to edit and try.
I hope it should be a way to hit a key to raise a point fast and easy. now you have to enter the measurement each time. That's too slow...
Rune
Try keeping the CTL or SHIFT key held down after making a multiple selection and keep the key help down while you click the buttons to edit.
John Mayo
