Civil 3D Forum
Editing Feature Lines with the Grading Elevation Editor
3 REPLIES 3
post8
313 Views, 3 Replies
Is there any way to hold the focus on the selected points in the Grading Elevation Editor?
When I select some points and use raise once, the points beein deselected. And then I have to select the points again if I want to rise more.
-Or is there any easier solution to select a point or some point on a feature line and raise/lower then fast and easy by step?
Rune
3 REPLIES 3
Citadel2012
in reply to: post8
Grab a feature line and the feature line editor ribbon should pop up. Hit "edit elevations" and click the first small icon on the upper left, "quick elevation editor." This allows you to set the elevation at each P.I./elevation point, as well as grade in/out. Hope this helps.
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
post8
in reply to: Citadel2012
thanks, but it's still a slow way to edit and try.
I hope it should be a way to hit a key to raise a point fast and easy. now you have to enter the measurement each time. That's too slow...
Rune
jmayo-EE
in reply to: post8
Try keeping the CTL or SHIFT key held down after making a multiple selection and keep the key help down while you click the buttons to edit.
John Mayo
Rail Community
