Civil 3D Forum
Editing Existing Styles
3 REPLIES 3
E_Shaft
319 Views, 3 Replies
I have a set of styles I helped create in 2010, the company I currently work for needs to have new styles added and I would like to use some of the styles I helped create to make my life a bit simpler in this process. I have created an Overall.dwt file using the current styles the company i work for has and I have imported my styles into this dwt. As im renaming these styles for my new company I noticed under the general tab for text style and block style I have text and block styles with my old companies name but i cant seem to find where the blocks or text style is being pulled from so i can edit it with a new name. So my question is where are these styles being saved so i can edit them,  any assistance would be much appreciated
3 REPLIES 3
C3D_TomR
in reply to: E_Shaft
I'm not sure if this is what you're asking but I suggest running the RENAME command. This will give you access to rename blocks, textstyles, linetypes, etc. in the current drawing.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
E_Shaft
in reply to: C3D_TomR
That was the exact comand i needed to finish this. Thank you very much.
C3D_TomR
You're welcome. It's one of my favorite commands along with FILTER.
Tom Richardson
Twitter | LinkedIn
Rail Community
