Civil 3D Forum
Editing Drawing Scales
6 REPLIES 6
DaveM
452 Views, 6 Replies
All,
I am working in a drawing that had all archetectual scales. I Need to insert scales like 1"=30' and so on. Usually when i go to this menu i can simply add them, but in this drawing they arent there. I started this drawing using the relitivly blank template ACAD.dwt because i am trying to build a company template and did not want any trash.
How does autocad chooses wich scales to show. In drawing setting it is set to US Survey foot.6-14-2013 2-54-26 PM.png
The link below talks about the issue, but i really do not understand the results.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Scale-List/m-p/3015870/highlight/true#M151812
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
6 REPLIES 6
Jay_B
in reply to: DaveM
Enter -DWGUNITS @ command line (note the dash) and set the drawing units to feet.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
DaveM
in reply to: Jay_B
6-14-2013 3-33-28 PM.pngThe image above shows that it was already set to feet, but i had never heard of that varible, thanks.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Jay_B
in reply to: DaveM
Next i would review and set DDUNITS as desired.
C3D 2018.1
C3D 2016 SP4
Joe-Bouza
in reply to: DaveM
This has been a known problem and can be fixed by modifying the registry key. looks like 2013 in your screen grab. I have attached reg edit file for your use. All disclaimers apply to editing registry blah blah blah
Your Name
Your Name
ToddRogers-WPM
in reply to: DaveM
Click the RESET button (shown in your screen shot) and, oddly enough, select Metric.  This will load what you're looking for
Todd Rogers
DaveM
in reply to: ToddRogers-WPM
Thanks, That got it.
I never tried tried the reg edit, but that could be the problem. I asked the IT guy to do a reinstall the otherday to try and get back the layout tools when entering layout tabs, and instead he just erased some stuff in the Registry. It did not fix anything.
Thanks everone involved.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Rail Community
