AutoCAD Civil 3D General
joshua.prettyman
Message 1 of 14 (152 Views)
Editing Default User Contours in Styles
152 Views, 13 Replies
11-29-2012 11:48 AM
In the surface styles dialog under analysis you can edit elevations, colors, etc. EXCEPT for user contours. What I would like to do is edit these for user contours, then when I created it there would be a default of sorts.
So the question... is there any way to set a default for user contours in the style?
*Pro
dgordon
Message 2 of 14 (147 Views)
Re: Editing Default User Contours in Styles
11-29-2012 01:27 PM in reply to: joshua.prettyman
I don't think there is.   You can have a style that is set to display them, but you can't create them until the surface is created.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Joe-Bouza
Message 3 of 14 (132 Views)
11-29-2012 04:31 PM in reply to: joshua.prettyman
Although, you can setup a "seed" suface with some dummy data to set the default user contours in the template with all the bells and whistles you want, add the data and the user contours will show
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Pro
dgordon
Message 4 of 14 (117 Views)
11-30-2012 08:16 AM in reply to: Joe-Bouza
Joe,
Very nice.  Way to think out of the box.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Joe-Bouza
Message 5 of 14 (114 Views)
11-30-2012 08:46 AM in reply to: dgordon
Sometimes we all get lucky, Bro :smileywink:
That technique can be taken to all c3d objects, but can create a messy template
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
joshua.prettyman
Message 6 of 14 (94 Views)
12-03-2012 07:04 AM in reply to: joshua.prettyman
I use the volume surface and the 0 contour to determine daylights where the grading can get rough. So a dummy surface doesn't work in this instance.
If there's no way than there's no way though. Thanks for your help!
Joe-Bouza
Message 7 of 14 (92 Views)
12-03-2012 07:08 AM in reply to: joshua.prettyman
Why not? create another dummy and the volume surface in the template
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
joshua.prettyman
Message 8 of 14 (88 Views)
12-03-2012 07:13 AM in reply to: Joe-Bouza
They're used multiple times throughout the drawing. It would simplify things a bit though. Thanks.
troma
Message 9 of 14 (84 Views)
12-03-2012 07:19 AM in reply to: Joe-Bouza
For that to work wouldn't you need the option to switch the Base & Comparison surfaces within the Volume surface?
(For the record, you should have that option anyway IMHO.)
Credit where credit is due! Give kudos or accept as solution whenever you can.
Joe-Bouza
Message 10 of 14 (81 Views)
12-03-2012 07:21 AM in reply to: troma
Pardon; I lost track of your thought? Why would you have to switch anything around?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
