Civil 3D Forum
Editing Corridor Sections
4 REPLIES 4
157 Views, 4 Replies
I just loaded C3D 2008 & now I can't manually edit the corridor sections. I was able to edit them in 2007. Is there a setting that I am forgetting. The alignment and corridor were created in 2008.
Thanks in advance...
4 REPLIES 4
By manually editing, do you mean geometry edit (grip edit a link for
example)?
You can perform parameter editing (change the slope value for example), but
I'm not able to make geometry changes either. I think this is broken.
Matt
miked
I assume you mean grip edit if so this is broken. I have been back to our reseller and they found the same problem so they went back to Autodesk. To data we have no satisfactory answer to this situation.
NVIDIA Quadro 600
Civil3D 2012 64x
Thanks for the help - I ended up changing the parameters (slope) in the dialog box for each section. A pain in the neck, but it worked...
nzeeben
IF you enter the command DisableSubSelection
Prior to performing your grip edits you should have no issues.
Nick Zeeben
Rail Community
