Just thinking of getting into the world of editing pipe network parts for my first time. I've used them for a while, but never created or edited a part.
I opened up part builder and quickly closed out again. It looks complicated!
I found this part in the .xml:
<Column desc="Wall Thickness" dataType="float" unit="mm" name="WTh" id="C2" visible="1" context="WallThickness" index="0">
<Row id="r0">75.0000</Row>
<Row id="r1">75.0000</Row>
<Row id="r2">75.0000</Row>
<Row id="r3">75.0000</Row>
<Row id="r4">0.0010</Row>
<Row id="r5">75.0000</Row>
<Row id="r6">75.0000</Row>
<Row id="r7">75.0000</Row>
<Row id="r8">75.0000</Row>
<Row id="r9">75.0000</Row>
<Row id="r10">75.0000</Row>
<Row id="r11">75.0000</Row>
<Row id="r12">75.0000</Row>
<Row id="r13">75.0000</Row>
<Row id="r14">75.0000</Row>
<Row id="r15">75.0000</Row>
<Row id="r16">75.0000</Row>
<Row id="r17">75.0000</Row>
<Row id="r18">75.0000</Row>
<Row id="r19">75.0000</Row>
<Row id="r20">75.0000</Row>
<Row id="r21">75.0000</Row>
<Row id="r22">75.0000</Row>
Seems to me quite simple to just edit 75 to 165 for all of the above lines, and be done! Can I do this, or is there a problem with editing them this way?
Thanks!
Mark Green
Working on Civil 3D in Canada
Solved by sirjoelsph. Go to Solution.
@troma wrote:
But I just discovered something. We're using the same catalog for 2011 and 2013. Up till now I was testing in 2013, and it is not working. But I went into Part Builder in 2011 so as not to make the .dwg unreadable for 2011 if I had edited it in 2013.
So, in 2011 it is all working fine. I just tested, and the pipes come in with the right wall thickness in a new drawing. But when I try the exact same thing in 2013 they come in with the old size. I didn't even run PartCatalogRegen in 2011, it just worked fine.
Are you sure you set the same location for both 2013 and 2011 for the PipeCatalogue? I had 2012 and and 2013 installed simultaneously on one computer, and (if I recall correctly) they both default to different locations for the Pipe Catalogue; i.e there's a folder for 2012 and another for 2013. You can set the 2013 to look at your 2011 Pipe Catalogue under Create Design>Set Pipe Network Catalogue> and then find the 2011 one.
I am now. I am meant to be, but I had it set wrong as noted earlier. We are in an office here, with the catalog on a network drive so all can point to it.
Mark Green
I wonder if you could delete the part list from prospector and drag the new one back in instead.
I still think the network would need to be re-referenced or parts swapped after the part list is redefined. I don't believe parts in a file will dynamically update if the part dims from partbuilder or part list changes. I think they need to be redefined or re-referenced with the new part list.
John Mayo
@Anonymous wrote:I wonder if you could delete the part list from prospector and drag the new one back in instead.
If I recall correctly, it's doable. On my second drainage design project I found it too much of a hassle to try and recreate the parts list and (especially) the rules for the new C3D file, so I dragged and dropped it from my old project to the new one.
I have yet to get around to updating my template to already include this, we're still learning quite a bit as we go along.
