I am new to Civil 3D upgrading from LDD2009. I am trying to edit some point descriptions brought in through a fieldbook import through my survey database. Under my survey database in Survey Points I hit EDIT POINTS and it brings up the SURVEY POINTS EDITOR. My points are listed as white observed points but when I click on the description cell it won't allow me to change anything. It must be something simple but I can't figure out what the issue is.
Welcome Mark!
Allen
Allen Jessup
CAD Manager - Designer
When you import survey data through the Survey Database, you have to edit the descriptions there (on the Survey Tab in Toolspace). C3D locks down your survey points.
There's also an option there to "Unlock in Drawing", which might let you edit the points directly in the drawing.
I am trying to edit my descriptions in my Survey Database under the Survey Tab in my Toolspace. I click on Survey Points-Points-Edit Points which opens my Survey Points Editor. The editor opens and all my points are listed with white backgrounds. When I double click on the point in any cell the drawing zooms to the point but does not let me edit anything.
I already have hit Survey Points-Points-Unlock in drawing many times which doesn't seem to do anything.
Mark
It seems that it depends on which version of C3D you are working with.
I am working with v. 2012 and it allows me to edit the point descriptions from the survey points editor by double clicking in the description cell for the individual points. Sorry...I don't know if you can edit the descriptions in earlier versions.
I finally realized what was going on. My Survey Databse was opened as read only, with the red circle next to it. I had to close the survey database and OPEN FOR EDIT. Then my points were free to be edited within the SUREVY POINTS EDITOR.
Sorry for the confusion.
