Active Member
marirf
Message 11 of 19 (169 Views)
Re: Edit grading
10-25-2012 12:06 PM in reply to: mathewk
Hi!
I´m going to attach an image that shows what I´m trying to say!
Mariana
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2015 - Infrastructure Design Suite
Windows 7 64 i7 47700 @3.40GHz 8GB Ram GeForce GT 630
mathewk
Message 12 of 19 (163 Views)
Re: Edit grading
10-25-2012 12:52 PM in reply to: marirf
Transitions have nothing to do with 2 grading objects intersecting as in your image.  You have the "Points" option only if you have a gap between gradings on the same feature line.  The original quesiton was about how to create a transition when te feature line has a single continuous grading on its entire length.  Two diferent techniques.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Neilw
Message 13 of 19 (159 Views)
Re: Edit grading
10-25-2012 01:03 PM in reply to: marirf
Your image shows what appears to be a corridor and a grading. The grading overlaps the corridor. So I gather you want to transition the grading to the corridor or vice versa. That will require a bit more convoluted workflow.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Active Member
marirf
Message 14 of 19 (156 Views)
Re: Edit grading
10-25-2012 01:11 PM in reply to: Neilw
No, I wanted to show you that the option [Points] appears. It is really only one feature line, the one that is selected. It is targeting the natural ground, the corridor is independent and has nothing to do with my problem.
Mariana
Joe-Bouza
Message 15 of 19 (141 Views)
Re: Edit grading
10-25-2012 01:28 PM in reply to: mathewk
Hi Matt
Any chance this video can be summed up in a few words for those that do not have access to youtube at work?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
mathewk
Message 16 of 19 (138 Views)
Re: Edit grading
10-25-2012 01:33 PM in reply to: Joe-Bouza
Let's say you have a building pad that dayllights at 2:1 all the way around.  Click the add transition button and specify a point, accept the default or set different slopes.  Add additional transition points and set their slopes accordingly.
Matt Kolberg
Joe-Bouza
Message 17 of 19 (136 Views)
Re: Edit grading
10-25-2012 01:33 PM in reply to: marirf
Mariana,
The image helps but the description is fuzzy. If I had to guess you invoked the transition option after the grade to surface was completed and c3d thinks you have two gradings to go between.
Might I suggest starting over and put the transitions where you want. from what I can see the grading doesnot look too complex to redo
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Neilw
Message 18 of 19 (128 Views)
Re: Edit grading
10-25-2012 01:51 PM in reply to: Joe-Bouza
It is not necessary to start over. You can insert a transition into a grading even if it is closed. Using the grading layout tools, select the transition tool and when it prompts for a location, pick any location in the grading and it will insert a transition. You can then delete it which will leave a gap in the grading. From there you can edit the gradings on either side of the gap and then fill it in with a new transition.
WIN 7 64 PRO
RADEON 6450, 1 GB
Joe-Bouza
Message 19 of 19 (121 Views)
Re: Edit grading
10-25-2012 03:01 PM in reply to: Neilw
Thanks for the motivation
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
