AutoCAD Civil 3D General
Active Member
marirf
Message 1 of 19 (275 Views)
Edit grading
275 Views, 18 Replies
10-25-2012 07:17 AM
Hi everyone,
I´m having some trouble about edit grading and hope that someone can help me.
I´ve done a grading "applying to entire lenght" but after done that I realized that I needed to do some located contentions. Is it possible to edit the grade for not applying it to entire lenght?
When I go to the modify tab, edit grading, it does not appears the option "apply to entire lenght?"
Mariana
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2013 - Infrastructure Design Suite
Windows 7 64 i7 2600 @3.40GHz 8GB Ram GeForce GTX 550
Message 2 of 19 (272 Views)
Re: Edit grading
10-25-2012 07:35 AM in reply to: marirf
I don't believe so. From what I remember once you choose to grade from the entire length you are stuck. You will need to delete the grading and use new options.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Active Member
marirf
Message 3 of 19 (269 Views)
Re: Edit grading
10-25-2012 07:41 AM in reply to: dasindog
That´s what I thought so,
unfortunately, my surface is "stitched" on the inside, if I do a new grade, with a new infill I´ll lose all my work
Mariana
Message 4 of 19 (260 Views)
Re: Edit grading
10-25-2012 08:15 AM in reply to: marirf
You are by no means stuck.  You can definitely make edits to it.
http://www.youtube.com/watch?v=WbuCVV_hreI&list=UU_5gUiM33gZ5nCshE0gp-jA&index=40&feature=plcp
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Message 5 of 19 (246 Views)
Re: Edit grading
10-25-2012 09:37 AM in reply to: mathewk
It still amazes me of all the little things I don't know about that can make such a big deal in a workflow. Thanks, Matt!
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
Message 6 of 19 (244 Views)
Re: Edit grading
10-25-2012 09:39 AM in reply to: marirf
Any time.
Matt Kolberg
Active Member
marirf
Message 7 of 19 (228 Views)
Re: Edit grading
10-25-2012 11:30 AM in reply to: mathewk
Hi!!! Thank you so much for that solution!
But I still have a question about the creation of a transition. In autocad C3D 2013, it offers me an option to create transition, after that, if you press enter, it won´t work, because I only have 1 grading, no slope difference. Also, it offers me the option of [Points], so, I press P, and create a transition, is that correct?
I ask that because I thought that the creation of a transition was only used when I had different slopes at the same grade encountering each other.
Mariana
Joe-Bouza
Message 8 of 19 (221 Views)
Re: Edit grading
10-25-2012 11:47 AM in reply to: marirf
I cant access Youtube here. What is the solution?
The transition tool can create a slope transition on the fly or expect at least two gradings along the feature line seperated by a gap. grading 1 would have slope 1 , grading 2 slope 2 and the transition flow btween them
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Message 9 of 19 (219 Views)
Re: Edit grading
10-25-2012 11:48 AM in reply to: Joe-Bouza
Just add a transition, actually a few of them.
Matt Kolberg
Message 10 of 19 (210 Views)
Re: Edit grading
10-25-2012 12:03 PM in reply to: marirf
I don't know what you mean Mariana.  It's working in 2013 the same way as it is in my video.  I have no "P" option when adding transitions.
Matt Kolberg
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
