AutoCAD Civil 3D General
*neilw
Message 11 of 22 (173 Views)
Re: Edit feature line radius
02-15-2010 02:08 PM in reply to: *neilw
By the way, the TAN TAN TAN circle tool doesn't seem to like 3D elements at
different elevations. Can you give it a go with the file I posted?
*Laurie
Message 12 of 22 (173 Views)
02-15-2010 02:09 PM in reply to: *neilw
Hi Neil,
Saw those requests and thought here's an idea for a custom program
pending Autodesk doing something.
I may have some time available mid year to entertain myself with it.
Laurie Comerford
neilw wrote:
> Thanks for that idea Laurie. The situation is I created numerous feature
> lines from an XREF. The curb radiii had been drawn with intermediate
> vertices sometimes more than one. I need to go through all the radii and
> remove the unwanted vertices, but doing so cause the arc to distort. I need
> an efficient way to fix all those arcs. Perhaps I could explode them all and
> use standard Autocad tools to clean every thing up. I'd have to create a
> static surface to use to restore the elevations after the clean up. Still
> that is a drastic fix when most of the arcs are fine.
> This is one of those frustrations brought on by custom objects. I've posted
> some CR's in the wish forum in regards to other problems with feature line
> editing and fillets if you care to see what other issues I've faced.
> As designers we need to focus our time and designing, not fooliong with
> workarounds to make the tools do what they are supposed to do. I'm finding
> this problem in every package I've tried lately. We in the civil field sure
> could use more efficient offereings!
BrianHailey
Message 13 of 22 (173 Views)
02-15-2010 02:10 PM in reply to: *neilw
http://screencast.com/t/NzZlZGZi
It appears that you can't create it exactly tangent, but you can get REALLY close.
Brian Hailey
http://www.cad-1.com
http://www.AtYourDeskTraining.com
http://Civil3DPlus.wordpress.com
BrianHailey
Message 14 of 22 (173 Views)
02-15-2010 02:11 PM in reply to: *neilw
Beats erasing and redrawing... most likely.
Brian Hailey
BrianHailey
Message 15 of 22 (173 Views)
02-15-2010 02:12 PM in reply to: *neilw
Basically, just draw a polyline, create the circle, erase the polyline.
Brian Hailey
*neilw
Message 16 of 22 (173 Views)
02-15-2010 02:18 PM in reply to: *neilw
Close enough for government work :smileyhappy:. Thanks again.
BrianHailey
Message 17 of 22 (173 Views)
02-15-2010 02:25 PM in reply to: *neilw
No worries. In figuring it out, I learned something new myself.
Brian Hailey
*neilw
Message 18 of 22 (173 Views)
02-15-2010 02:27 PM in reply to: *neilw
I think some custom tools would be a really handy for this stuff Laurie. I
seem to run into this a lot.
Distinguished Contributor
GaryElswick5627
Message 19 of 22 (174 Views)
02-17-2010 04:19 AM in reply to: *neilw
Not sure if you have control over how the field crew obtains the shots but the one point curve is designed for this situation. It is mentioned in several of the AU screencasts on field to finish and is shown about half way down on the "Curve Segment Codes" page in Help.
Civil3DReminders.com
Message 20 of 22 (174 Views)
02-17-2010 05:52 AM in reply to: *neilw
You can get a little closer using this method: http://screencast.com/t/MTBiYmVh
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
