Civil 3D Forum
Edit feature line radius
21 REPLIES 21
Message 1 of 22
1189 Views, 21 Replies
I run into this problem frequently. How do I edit a feature line radius to
make it pass through a point?
In the screen capture you can see a curb bull nose that is not tangent. I
cannot get it to be tangent using the Edit Curve tool. Aside from breaking
the feature line and recreating the curve, how can I fix it?
21 REPLIES 21
Message 2 of 22
Hi Neil,
There's probably a better way, but you could create an alignment which
has good pass through features and then trace over it to get the feature
line location.
Laurie Comerford
Message 3 of 22
Thanks for that idea Laurie. The situation is I created numerous feature
lines from an XREF. The curb radiii had been drawn with intermediate
vertices sometimes more than one. I need to go through all the radii and
remove the unwanted vertices, but doing so cause the arc to distort. I need
an efficient way to fix all those arcs. Perhaps I could explode them all and
use standard Autocad tools to clean every thing up. I'd have to create a
static surface to use to restore the elevations after the clean up. Still
that is a drastic fix when most of the arcs are fine.
This is one of those frustrations brought on by custom objects. I've posted
some CR's in the wish forum in regards to other problems with feature line
editing and fillets if you care to see what other issues I've faced.
As designers we need to focus our time and designing, not fooliong with
workarounds to make the tools do what they are supposed to do. I'm finding
this problem in every package I've tried lately. We in the civil field sure
could use more efficient offereings!
Message 4 of 22
Click Home tab, Draw panel, Best Fit drop-down, Create Best Fit Arc .
You can find the radius by drawing a new arc.
John
Message 5 of 22
That's a nice tool John.
Now if only we could use it to edit a feature line arc. I still have to
break out and delete all the bad feature line arcs, convert the new arc to
FL and re-join and regrade. If I had gradings applied it would be even more
work.
Would you not agree that we need better editing capabilities for FL arcs?
Message 6 of 22
BrianHailey
You mean like this?
http://screencast.com/t/MGQxYThkZT
Brian Hailey
http://www.cad-1.com
http://www.AtYourDeskTraining.com
http://Civil3DPlus.wordpress.com
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 22
Yes Brian like that. My challenge is I need the arc to be tangent to the
driving lane of the parking lot. Can you do that?
wrote in message news:6336852@discussion.autodesk.com...
You mean like this?
Brian Hailey
Message 8 of 22
BrianHailey
Yup.
http://screencast.com/t/ZGNkYWRl
Brian Hailey
GEI Consultants
My Civil 3D Blog
Message 9 of 22
Would you mind showing me how you do it with this file (2010 format)?
Message 10 of 22
My apologies. I didn't notice you had a screencast with your last post. I
see what you are doing now. Quite a few steps there.
Thanks though.
Message 11 of 22
By the way, the TAN TAN TAN circle tool doesn't seem to like 3D elements at
different elevations. Can you give it a go with the file I posted?
Message 12 of 22
Hi Neil,
Saw those requests and thought here's an idea for a custom program
pending Autodesk doing something.
I may have some time available mid year to entertain myself with it.
Laurie Comerford
Message 13 of 22
BrianHailey
http://screencast.com/t/NzZlZGZi
It appears that you can't create it exactly tangent, but you can get REALLY close.
Brian Hailey
GEI Consultants
My Civil 3D Blog
Message 14 of 22
BrianHailey
Beats erasing and redrawing... most likely.
Brian Hailey
GEI Consultants
My Civil 3D Blog
Message 15 of 22
BrianHailey
Basically, just draw a polyline, create the circle, erase the polyline.
Brian Hailey
GEI Consultants
My Civil 3D Blog
Message 16 of 22
Close enough for government work :). Thanks again.
Message 17 of 22
BrianHailey
No worries. In figuring it out, I learned something new myself.
Brian Hailey
GEI Consultants
My Civil 3D Blog
Message 18 of 22
I think some custom tools would be a really handy for this stuff Laurie. I
seem to run into this a lot.
Message 19 of 22
GaryElswick5627
Not sure if you have control over how the field crew obtains the shots but the one point curve is designed for this situation. It is mentioned in several of the AU screencasts on field to finish and is shown about half way down on the "Curve Segment Codes" page in Help.
Message 20 of 22
Civil3DReminders_com
You can get a little closer using this method: http://screencast.com/t/MTBiYmVh
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Rail Community
