I have a proposed surface that has been made by selection polyline with a z elecation as contours. Is it possible to have civil 3d easily change the weeding and supplementing factors to a tighter value after it has already been made?
You must edit the linework BEFORE adding it to the surface. You can't change it after. You'll have to remove, edit then add again.
