Civil 3D Forum
Edit Xref-in-place & points disappear
5 REPLIES 5
CADmgrMike
1047 Views, 5 Replies
Scenario:
1. You have a base map with survey points inserted.
2. You create a sheet, xref the base map, freeze survey points in base map, insert survey points into sheet so they can be manipulated for visual clarity.
Problem:
In sheet drawing, using the edit xref-in-place command to edit base map causes the points to want to be reinserted and in a lot of cases, when the sheet drawing is re-opened, the points are completely gone.
Anyone else have this issue or know how to resolve it?
Thanks.
Mike Porter
https://provostandpritchard.com/
5 REPLIES 5
Jeff_M
in reply to: CADmgrMike
Do not use EditInPlace with Xrefs! Open the Xref, edit, save, close, reload.
CADmgrMike
in reply to: Jeff_M
That's well and good if you're training a new user, but when a user has 20+ years CAD experience and they've used this command without issue until C3D came along, it's a pretty tough sell at that point. 🙂
Mike Porter
Jay_B
Old dogs can learn new tricks.Smiley Wink Select xref>rt click>open xref>(directly below edit xref in place selection).
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Jeff_M
I've been using Autocad products for 28 years. The first time I found that EditInPlace Fubars C3D drawings I have never used it again. I guess I'm just a quick learner Smiley Happy And actually, when the EditInPlace was introduced, I was a LDT user which didn't allow it in the first place so it's one of those things that I avoid at all costs, with the lone exception of I will see if it will work every few releases just in case....
CADmgrMike
in reply to: Jeff_M
That seems to be the consensus I hear from multiple places. Don't use it. Smiley Mad
Just one more thing to add to the list of broken parts.
Mike Porter
Rail Community
