kdixon
Message 1 of 6 (243 Views)
Edit Units for Pipe Properties
243 Views, 5 Replies
01-15-2013 04:13 PM
I am setting up a parts list using The Metric Catologue. In the Pipe Properties the Pipe Diameter shows mm but the Minimum Curve Radius shows inches. The Units are Greyed-Out. Is ther a way to edit these Units?
Kirk Dixon
Product Support
SethHall
Message 2 of 6 (219 Views)
Re: Edit Units for Pipe Properties
01-17-2013 09:03 AM in reply to: kdixon
Did you by chance start an imperial drawing and point to the metric catalog with SETNETWORKCATALOG?
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
kdixon
Message 3 of 6 (215 Views)
01-17-2013 09:27 AM in reply to: SethHall
No, All my Templates have a Metric Base. We never work in Imperial here. [KRD-EMAIL SIG]
Product Support
SethHall
Message 4 of 6 (200 Views)
01-18-2013 12:56 PM in reply to: kdixon
After a little poking around, the unit information is stored in this file: AeccPartParamCfg.xml Typically located here:
C:\ProgramData\Autodesk\C3D 2013\enu\Pipes Catalog\Aecc Shared Content
<AeccDfParameter name="MCR" desc="Minimum Curve Radius" context="MinCurveRadius" index="0" datatype="Float" usage="Double_Distance" unit="in" visible="True" internal="True"/>
You should be able to change the unit value above and it should populate in Civil 3D.
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
kdixon
Message 5 of 6 (180 Views)
01-21-2013 07:53 AM in reply to: SethHall
Thank you very much, that worked. Appreciate it!! [KRD-EMAIL SIG]
Product Support
SethHall
Message 6 of 6 (168 Views)
01-22-2013 05:55 AM in reply to: kdixon
Great!! Glad to help!
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
