Civil 3D Forum
Easy Survey Figures question
2 REPLIES 2
lhampton
576 Views, 2 Replies
Im trying to edit a figure line using the Survey Figure Properties after importing points from a file, the thing is, no points show up to be edited in the Survey Figure Properties dialog at the bottom, i tried re-importing with into a network, no dice. Seems like im just missing a check box somewhere, the points are in the file, i just cant edit the figures!
Intel i7 2600 /z68 Gigabyte
8gigs DDR3 1800
Intel 320 Series SSD
Quadro 600 (1gig)
C3D 2016 / LDT 2009 / Win7 x64
2 REPLIES 2
Cadguru42
in reply to: lhampton
If you are using 2013 you have to download the fix for that.  Then, you have to click on a mysterious button (that has nothing in the help files explaining) to convert from a vector based figure (which every object in Autocad already is) to a chain based one.   Then you can see the figure nodes.  Why this was even added, who knows?  I can't see a reason for it other than to make a change for the sake of change and say they did something in this release.
C3D 2022-2024
Windows 10 Pro
32GB RAM
lhampton
in reply to: Cadguru42
Sigh, Autode$k fails again. Thanks for the info got the patch and it worked, i didnt have to click the convert button though ,its working now....
Thanks!
8gigs DDR3 1800
Quadro 600 (1gig)
Rail Community
