travanx wrote:
> I know HTML somewhat, but I am a little unsure of how to get XML to work with the file. I am going to post the outputted .xml file I have, which only has 3 numbers; cut, fill, and net. Can someone help me with what I need to have for the .xsl file.
Travanx,
First thing to ensure is that your LandXML files are valid according to
the schema posted on http://www.LandXML.org/
I've modified your LandXML file slightly to accommodate that. I wrote a
small XSL style sheet that will take this LandXML file, look for all
SurfVolume elements and spit out the numbers in the file. The output
HTML file is also in the attached ZIP file.
Since I'm posting this via a newsreader, I'm not sure if the attachment
will show up properly, but if it doesn't I'll go through the web
interface and add it.
Please feel free to modify the XSL file to do what you want and
contribute it to the group.
Himanshu Gohel. Civil3D Team, Autodesk, Inc.
Autodesk Civil3D Product Information: http://www.autodesk.com/civil3d
