Civil 3D Forum
EG Profile
17 REPLIES 17
Message 1 of 18
bgriffin291
770 Views, 17 Replies
EG Profile
I need to extend the existing ground profile. I previously had stopped the profile at 25+00 as shown in the attached. However, I need to add on another 100' to 26+00. I can only view info in the Profile Properties. I can't change the end station.
How do I get it to extend?
Thanks.
17 REPLIES 17
Message 2 of 18
awood
in reply to: bgriffin291
Select Profile View, Right-click, choose Profile View Properties, then the Stations tab.
HTH
AWood
Message 3 of 18
First thing. Are you adding 100' to 25+00 or 26+00?
1. Not sure in your "picture", why is the existing ground missing from Sta
25+00 to 26+00?
2. You can always use the line command and draw it.
3. Turn on your triangles and make sure you have a surface where your
alignment crosses since it should be showing in your "picture" if that is
the case.
Bill
wrote in message news:6387192@discussion.autodesk.com...
Thanks.
Message 4 of 18
bgriffin291
That doesn't extend the actual profile itself, only the profile view, i.e. gridlines, etc.
I need the surface profile to be extened.
Message 5 of 18
bgriffin291
When I originally created the surface profile I stopped it at 25+00. The surface continues to 46+00, I just didn't need all that extra profile. I'm only designing 1000' of road.
You cannot modify an EG profile using the layout tools either. I believe that because it is surface dependent using the line command is not an option.
Message 6 of 18
Create a new surface profile from 25+00 to 26+00
"bgriffin291" wrote in message news:6387200@discussion.autodesk.com...
> option.
Message 7 of 18
If you extend your alignment your EG profile will also extend.
Matt Kolberg
Global CADD Systems - A division of Cansel
"bgriffin291" wrote in message news:6387197@discussion.autodesk.com...
> gridlines, etc.
Message 8 of 18
castled071049
As an earlier poster noted, extending the alignment will automatically add the necessary EG profile to your profile view.
Message 9 of 18
To further expand on my item 3. in my earlier post. You may have a "hole"
or no existing ground in your Surface along this alignment..
Bill
"Matt Kolberg" wrote in message
news:6387214@discussion.autodesk.com...
Matt Kolberg
> gridlines, etc.
Message 10 of 18
If you extend the alignment and the profile view gets larger without the
surface profile getting larger then you are either missing surface data
under the alignment or the profile has lost it's link to the surface. Add
data or resample the profile.
John
Message 11 of 18
It could also be that a 'hide' boundary is applied to the surface. If this
is the case remove the boundary & apply a mask. A mask will still show the
data in profile.
John
Message 12 of 18
I replied to this earlier, but it isn't showing up for some reason....
Create a new surface profile for 25+00 to 26+00.
When you create a surface profile, and specify the stations to use, you
cannot later change the sampled stations.
Jeff
> option.
Message 13 of 18
castled071049
You most certainly can change the sampled stations in a surface profile. Just grip edit the alignment to make it longer and the corresponding sampled EG profile will increase proportionally. (Providing, of course, there exists viable EG surface under the increased alignment length, as pointed out by others here.)
Message 14 of 18
Sorry, but that ONLY works when you sample the entire alignment to begin
with. When you specify a station range to sample, as the OP noted was done,
you cannot later change it.
"castled071049" wrote in message news:6387506@discussion.autodesk.com...
Message 15 of 18
castled071049
Jeff: You are right and I stand corrected. I missed that the OP had only sampled part of the alignment at the start. To be honest, I have never sampled less than the full alignment, feeling like I can size the PV accordingly if I need less.
Message 16 of 18
rkmcswain
I have seen multiple cases in C3D 2013, where the full alignment was sampled, but yet stretching the alignment after the EG profiles are drawn - does not automatically stretch the EG profiles.
The fix for this is to go into Profile Properties, on the Profile Data tab, change the Update Mode to Static, press Apply, then change it back to Dynamic and press Apply.
Having said that, I just created an alignment and profile in a dummy drawing and it works like you would expect, maning that you stretch the alignment, and the EG profiles stretch. So I can't recreate the problem on demand, but I know I have seen it on multiple occasions.
R.K. McSwain     | CADpanacea | on twitter
Message 17 of 18
jmayo-EE
in reply to: rkmcswain
Thanks for the update on this Randy.
Could this be one of those issues that only appears when you open an previous version file on 2013?
John Mayo
Message 18 of 18
rkmcswain
in reply to: jmayo-EE
That is very possible. I don't think the drawing with the problem was started in an earlier version --- but with cut+paste, etc., you never know what strange things can get carried over from DWG to DWG....
Rail Community
