Show only
Search instead for
I am in the revision process on a project and several of the dynamic labels that were created on some of the structures and pipes have apparently lost their justification. It appeared previously that the justification was kind of an automatic function.
I know when you switch from a typical layout state to a "dragged state" it can appear they have lost their original justification. You can setup the dragged state to "as composed" to have it coincide with the typical layout state.
The text is in the "dragged state" and the setting is for "stacked text". It was fine when we first printed the job and as far as I know, nothing has changed.
try changing the leader justification to false under the dragged state column so it follows your justification under the Text Component Editor as opposed to the leader. I have noticed that it responds better this way although, not always.
