Civil 3D Forum
Dynamic Input and grip editing Profiles
2 REPLIES 2
miagear
413 Views, 2 Replies
When grip editing a proposed vertical alignment it appears that if you do NOT have the DYNamic input turned on, you sometimes will not get the slope/grade locking grips on the profile. You also cannot use the TAB key to cycle between elevation and station for on-screen editing of data. Comments...
Mia
2 REPLIES 2
in reply to: miagear
wrote in message news:4849642@discussion.autodesk.com...
Most of the time I keep DYNamic input turned off and I don't see this issue
with profile grips at all. However, I remember another post about this
issue...here it is:
http://discussion.autodesk.com/thread.jspa?messageID=4330818
Please see Rad Lazic's post at the end. Does that sound like it's the case
for you? Although in C3D 2006 I do get grips for all PVIs that are within
the view, even if part of the proposed vertical alignment is outside the
height bounds of the profile view.
The TAB key is working for me. The focus changes from the elevation to
station when I press it & I can type in a value to change the sta/elev.
Only thing is the osnap tooltip seems to obscure the input field at times.
Also, in each post, please state the version & service pack level of C3D
that you are referring to. In your case DYN gives me a clue that it's 2006,
but with some posts it's not easy to tell.
Himanshu Gohel. Civil3D Team, Autodesk, Inc.
Autodesk Civil3D Product Information: http://www.autodesk.com/civil3d
miagear
The disappearing grips very well may not be associated to the Dynamic input and this may simply be coincidental to my turning off and on the Dynamic input feature. I too am unable to faithfully reproduce the problem however, it has happened to me (and apparently others too) a few times in one day.
Mia
Rail Community
