Civil 3D Forum
Duplicate Figure Lines
5 REPLIES 5
480 Views, 5 Replies
I am a surveyor / field designer in a municipal environment.
I was wondering why, when I bring in a FBK, C3D produces duplicate figure lines?
What am I doing wrong? Did I miss something?
I am a newbie from LDD and have to learn this by osmosis as the Tutorials and docs are a little light in the survey area.
I guess they think that surveyors are smart enough to figure this stuff out.
All help is appreciated.
D Dell
5 REPLIES 5
Attach the FBK and we can have a look.
Matt Kolberg
Global CADD Systems - A division of Cansel
wrote in message
news:6350679@discussion.autodesk.com...
> Hello,
> lines?
> out.
> Thanks,
> D Dell
It shouldn't unless the coding in the FBK tells it too or you forgot to
erase the prior imports figures..
Matthew Anderson, PE
ddell@thunderbay.ca wrote:
> Hello,
> Thanks,
> D Dell
I thought it shouldn’t duplicate them.
I’ve started a New Survey Database and imported control through a Pts txt file.
Brought in my fieldbooks and produced duplicate figues.
I’ve done this several times on different machines with the same results. (no editing, just importing)
I noticed this when I attempted to edit the figure line and found duplicate lines.
Maybe it’s a drilldown setting box checked off.
I am including pics of my Project and a fieldbook with some test figure commands.
All the fieldbooks imported react the same way.
I am using Civil 3D 2010.
I will continue spelunking the settings for a resolve.
Thanks again.
D
I was having the same thing happen. Somebody finally pointed me towards a checkbox on the "Import Field Book" settings box. Try un-checking the "Process linework during import" box. Worked for me.
Yep, that does it.
One of the hidden 'features' I guess.
I unchecked 'insert figure objects' setting during import and left "process linework during import" checked.
Got duplicates.
So, to the surveyors in the crowd, Do Not 'process linework' from a Fieldbook or you will have duplicate figures.
You can insert figures while you import or later...your chose with no duplicates.
I am still unclear with the differences between 'linework' and 'figures'.
Thanks Mrdavek
D
Rail Community
