Hi.
How can I get a list of all codes from all stock subassemblies in Civil 3D?
I would like to have a list of all codes in Excel.
I have other dubts about codes like:
Do we have to use the same codes, for example ("Top", "Datum",...) for all the subassemblies?
Is there any rules,specifications or table about this?
I have a realease (Civil 3D 2015) in Spanish and I don´t know if the codes must be in English or Spanish.
Thanks.
Solved by fcernst. Go to Solution.
Look to the Subassembly Reference in the Help system of Civil 3D 2015.
Some stock subassemblies, example being LaneSuperElevationAOR, have hardcoded link codes. These cannot be changed. Others, like LinkWidthandSlope, have changeable link codes. The Subassembly Reference will tell you the codes for all stock subassemblies.
Regarding spanish and english, for those codes that are changeable by the user, you can use any language or none. You could use Top or DQGQVSRAV.
You do not have to use the same codes from sub to sub. Any or all codes can be added into the corridor surface definition.
..Some stock subassemblies, example being LaneSuperElevationAOR, have hardcoded link codes. These cannot be changed. ..
Not true...Please see this link.
I have changed my LaneAOR ETW to EOP.
Thanks, Fred. I didn't know about this option.
The possible downside is that if you change Top for one hardcoded subassy, you're changing it for all.
Best regards,
Tim
Thank you both.
That thread is very interesting!
In my Civil 3D 2015 in Spanish, I have 2 files:
C3DStockSubassemblyScripts and C3DStockSubassemblyScripts_es-ES
I attach my default C3DStockSubassemblyScripts_es-ES if someone wants to look at it.
http://www.mediafire.com/download/5n82xv7m3bcujmq/C3DStockSubassemblyScripts_es-ES.rar
I have copied them to Excel.
I think it must be a way to select that file in Civil 3D as a default file to use. Then, instead of modifying your C3DStockSubassemblyScripts file, you could create a new file.
If I have understood well, if we use a stock subassembly, it saves itself its Index Number, so if we open the drawing in Civil 3D (in Spanish) then it recognizes the code from the Index Number.
I would like to know if we could make the same for customized subassemblies using Index Number too.
Other possibilty for customized subassemblies, is use Input parameters(in SAC) for codes as (string)
