Civil 3D Forum
Drop down menus in dialog boxes appear blank and cursor doesn't echo
38 REPLIES 38
Message 1 of 39
4679 Views, 38 Replies
In dialog boxes the drop down menus appear blank until I drag the mouse over it then the contents appear as I drag the mouse across. Also the cursor doesn't echo back (flash). I have tried updating drivers to no avail.
Running Civil 3D 2011 with all updates.
Windows 7 64 bit
16 gig ram
Quadra fx 1800
Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
I have attached a couple images to illustrate.
38 REPLIES 38
Message 2 of 39
AlmasSuljevic
My first guess is that your graphic card may need an upgrade.Try following before that:
1. Check if you get the same behavior on other drawings
2. Type 3DCONFIG and go to Manula Tune, toggle "Enable Hardware Acceleration", Apply
3. If you et the same issue on both occasions then I would see if upgrading video driver helps. Just an idea.
Good luck.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 39
in reply to: AlmasSuljevic
Thanks for the input. Your suggestions had already been looked at. Problem persists.
Message 4 of 39
AlmasSuljevic
Can you post your drawing? I can try to open it on my machine to see if it's drawing specific.
Almas Suljevic
Autodesk, Inc.
Message 5 of 39
Due to confidentialy reasons I cannot post the drawing. However I can confirm this is not Drawing related.
Message 6 of 39
hgohel
Which driver version do you have installed?  Check this list for a list of supported driver versions for the Quadro FX1800 with C3D 2011 on Win7 x64.
Can you confirm that you have Update 1 for Civil 3D 2011 installed?
Himanshu Gohel
Autodesk, Inc.
Tags (1)
Message 7 of 39
Quadro fx 1800
driver 266.45
C3D has all updates.
Message 8 of 39
hgohel
You can try turning off hardware acceleration from within C3D/AutoCAD using the 3DCONFIG command -  restart C3D to make sure the settings are in effect.  Check whether your problem is resolved.
From the snapshots you posted, you have a "desktop manager" software that might be affecting display of windows?  If so, you might try disabling that temprorarily to see if that helps.
If not resolved, you may want to downgrade your graphics driver to one that is in the supported list - the one that you have installed isn't listed as supported/certified as of today.
Himanshu Gohel
Autodesk, Inc.
Message 9 of 39
Tried reverting to this approved driver: 8.17.0012.6570. Did not change anything. Also tried running without hardware acceleration,. no change.
Message 10 of 39
hgohel
Great!  That rules out a lot of what C3D/AutoCAD depends on for proper display.  Let us know the results after you disable the display manager software that seems to be installed on your system (referring to the extra button with <-> on the windows in your snapshots).
Himanshu Gohel
Autodesk, Inc.
Message 11 of 39
in reply to: hgohel
I did have the NView Desktop Manager installed, and it was initially turned off. to be safe I uninstalled. I do however still have the NVidia Control Panel Installed.,
Message 12 of 39
in reply to: hgohel
Heres another example of before ad after opening the inquiry box. Upon hitting the drop-down arrow the pull down menu appears blank, once hovering the noise just inside the contents appears.
Message 13 of 39
hgohel
Even in your latest snapshots I still see the <-> button on the window.  If you've uninstalled the display manager software, please reboot your system to verify it is completely uninstalled/not in use and test again.
Himanshu Gohel
Autodesk, Inc.
Message 14 of 39
in reply to: hgohel
Well looks like we got it, but time will tell for sure. The <--> symbol was for a program called Team Viewer. Its a remote desktop application.
http://www.teamviewer.com/index.aspx
Immediately after I uninstalled it the inquiry menu worked properly. I will assume that the problem is resolved at this point. Thanks so much for the help!
Message 15 of 39
hgohel
You're welcome & thanks for the follow-up.
Himanshu Gohel
Autodesk, Inc.
Message 16 of 39
wfberry
in reply to: hgohel
Kudos to H for picking up on that one.
Bill
Message 17 of 39
LaneLizard
I have the same problem but disabling the Nvidia control panel did not correct it and I have no <-> in the top right corner of my screen. Any other ideas?
Message 18 of 39
First ofcourse, make sure you have all teh latestest drivers etc.
I would take a look through your add/remove programs list. Check for any peice of software that might want to access your screens somehow like a removte viewer, desktop manager or anything else a bit dodgy.
If you still have trouble post qa screen shot and a system summary.
Message 19 of 39
Also check if the company you work for has any remote assistance software....
Message 20 of 39
LaneLizard
Here's the program list, a typical screen shot is to follow.
Rail Community
